Scrach building plan transfer tips
JDSnavely
There are a number of helpful things on the FT website. There are tips for printing the plans correctly. Some like to glue them on poster board with spray glue and make a template. I prefer to print the "A" plans 8.5X11and tape them together. Then cut out each part leaving a 1/4 inch edge. Then I use thin strips of blue painter's tape to tape the parts efficiently on a piece of poster board. Then I cut the plans out through the paper. If you start with the red dotted lines (not cut completely through both sides of the foamboard) then retape the line so it doesn't come apart it goes pretty easy. Make sure to put marks on all the green placement marks. Finish with the solid lines (cut all the way through). This also allows me to use up all the larger scrap from earlier builds too.
Newme
Thanks i like your method
JDSnavely
Make sure when copying from adobe you choose "auto" and copy at 100%. Took me a little to figure out how to print in the center of the paper. LOL. I've made templates from the kits as Josh had sugested where there are no plans (Trojan and Hellcat), and these are also nice. However, if I had access to plans, I would print them and use the method above.
JDSnavely
Above is the thread on scratch building from another on the forum.
Have fun!! My one son and I like building as much as flying!
Newme
Thank you
SP0NZ
FT CAD Gremlin
Admin
Anyone have any tips on transferring the build plans to the foam board for cutting
Here is the method I used to use, and it still works very well. I have switched to printing the tiled sheets on card stock now which also works very well for a reusable template.
And here are my tips for printing the plans:
Foamforce
If you only use a set of plans a couple times, the fastest and most accurate way that I’ve found is…
  • Print 11x17 (B size) if you can, 60% less trimming. Big office printers can do this.
  • Use a framing square to trim both edges at once. If you have 11x17, this means you only have to line up your cut once per sheet of paper, then cut both edges.
  • Tape the sheets together.
  • Use a kid’s glue stick to go around the edges of the parts on the back of the printed plans, then stick the plans to the foam board.
  • Cut right through the plans. Do inner cuts on each piece first because they’re only glued around the edges, so if you cut the outside first, the inside will become separated and move.
Newme
Has anyone used the foam board for grease markers it looks the same but one side has a clear plastic coating .the other side is paper like normal.it is the only thing i have available in my small town.not sure about the durability. Seems like it should work what do you think.
Xamith
I'd be worried about it being too heavy but could be worth a shot! Just need to fly faster and adjust your CoG to accommodate a heavy tail.
Newme
Just a heads up do not use Readi Board Readi Erase.this type of board has a plastic coating on one side I thought it may be more durable but whenever you make a 50% cut it delaminates from the plastic side almost immediately and with little to no effort. Luckily I tested it before I got to far into build.
Newme
Had trouble with center of gravity then read that it was common with this aircraft. My solution was to build a hatch so i could get my battery as far forward as possible i then secured it with a bbq skewer sits in there rock solid but not sure how the bump will effect performance may paint it up to look like a radiator
demotors
I print directly on card stock. Once everything is tiled and taped its easy to just lay the card stock on foam board. I usually use small strips of tape to hold the card stock in place. When I'm finished the card stock templates get paper clipped together. I save them in a big folder made of FT cardboard cutting boards.
Foam Folder
I use the foamboard marker boards for fuselage, covered with hobby vinyl, makes a smooth finish.
