Scratchbuilding a EPP Gentle Lady for a friend
cdfigueredo
Full weight 350g. I hope that after gluing the outer sections of the wings, add reinforcements to the center and supports for the suggestion rubber the weight does not exceed 500g. I think it goes very well for taking into account that the plane indicates a weight of between 22 and 25oz (623g - 709g)
cdfigueredo
The Gentle Lady is almost finished. Yesterday there were more advances in the fuselage and wings. I love the slim shape and the smooth curves.
IMG_20201011_174234.jpg IMG_20201011_200934.jpg IMG_20201011_200924.jpg IMG_20201011_200854.jpg IMG_20201011_201012_1.jpg IMG_20201011_201018.jpg IMG_20201011_201033.jpg
The total weight including electronics is 376g, but I will have to add some weight on the nose for balance. So I assume I can get to 450g maximum.
The original plane should weigh between 623g and 709g so I think I am fine. Even if I reach 500g I would still maintain a favorable weight.
I also plan to cover the leading and trailing edges with paper and glue for reinforcement. Especially the trailing edge.
cdfigueredo
Hello to all!
Finally the maiden was last Saturday. With a final weight of 480g, I flew magnificently. :cool::cool::cool:. We tried several hand launchings, all of them perfect. It was a little windy, so we had a little extra help.
We still have to reinforce the central union of the wings, but everything has been a success.
cdfigueredo
Congratulations... It flies great! Now to find a hill or roof to throw it from. Also, You can put a hook on it and pull it up with tow line.
Thank you my friend! yes we are very happy with the result! it flew really smooth.
the last test we made was pull it up with a tow line but wings did not resist the stress. that-s why i must reinforce it.
Will try again next saturday.
Pilotr2020
How do you cut it without warping the wing? When I try to tighten the wire it heats up and then loosens, how do you keep the wire tight?
Move the towhook forward from the CG by about 2 thumbs width, and NEVER add up elevator on tow.
