I got my own solution today. It requires at least 2 mix channels to work and optionally another one for fully integrate with an elevator.
Instruction below:
- Left flap - channel 5 (screen1)
- Right flap - channel 6 (screen1)
- Turn ON your additional 3-pos button (screen2) (in system options - Aux switches)
- Change channel 5 in options as Reversed (screen3)
- Set channel 5 and 6 on same auxiliary button in Aux channels (screen4)
- Set "Mix1" as self mix of Channel 5 (screen5) (ON, Ch5, Ch5, 0%, -50%, +25%)
- Set "Mix2" as self mix of Channel 6 (screen6) (ON, Ch6, Ch6, 0%, -50%, +25%) (values same as Ch5)
- Now it's complete guide for 3-pos flaps (0 - 0%, 1 - 50%, 2 - 100% of range)
Optionally for fully integrate with elevator to compensate pull up of your airplane just set another "Mix3" like below:
- Set "Mix3" as mix Ch5 / Ch2 (screen7) (ON, Ch5, Ch2, 20%, 20%, +10%)
Endpoints should be on default values 100%.
All changes u can see in options tab "Display". The problem is that it takes all of Mix channels.
If anyone know another/better solution please post below.
Best regards.
