Hi all, I've only been in the hobby for a few months, but it is my new thing.
I built a Simple Scout because I was looking for something gentle to keep from crashing so much as I build skill. It has now crashed enough that it will require a new build.
I had to move the aileron servos 1" outboard so that I didn't have to reverse the channel. That worked well, and allowed the same transmitter setup for multiple planes. I use a DXe.
I am thinking about doing a Rev 2 build that will cut the aileron surface down by about 1/3. It will leave the outboard 1/3 aileron surface fixed out to the wingtip, and only control via the inner 2/3 of the aileron.
For this plan, does anyone see any problems with flight dynamics by using the inner 2/3 of the wing trailing edge as an aileron surface? My problem with this plane is that it was WAY too twitchy on the ailerons, even on low rate (70%), and with a 30% expo. When I flew on low rate it was not responsive enough on the elevator/rudder.
2nd question: Concerning expo (new to this), what would a good expo curve look like? I want something that keeps me from overreacting, and getting me into trouble. It seems that my DXe expo only allows relaxed ramp on the bottom and top, and steep in the middle, or reverse that to get quick ramp on the ends with a shallow ramp in the middle.
Edit: I just realized I had -30% expo instead of positive. No wonder it was a twitchy mess. I guess I didn't understand the displayed curve... Here's an attached pic of what it is NOW, post mortem...
Thanks!
Thanks!
