basslord1124
Do you have videos on youtube? I think I may have watched them. My plane has a 2215/10 motor and am running a 10x4.5 prop, I tried the 10x7 but it ran the amps up and the motor got warm. I'm not sure what this motor can handle amp wise.
My sons motor is a B4023 that came off of his old trainstar and originally used a 12x6 prop with a 30 amp speed control. i may have him put the 12x6 on and try it that way to see if theres an improvement over the 10x7 he has now.
The 4s battery wont produce more torque will it?
Pick up a wattmeter, that will tell you how much watts and amps she's using. You can get em for about $15-$20. Warm is ok for a motor, hot is what you want to avoid. Oh, and yeah I've got some videos of my experience with the Storch...youtube channel is in my signature. I think a good portion of motors can all be the same they just have different manufacturer labels. So I'd compare what specs you know about your motor (KV rating, weight, dimensions, etc) and compare with ones out there that look the same. I'd say you'll eventually find it.
