rcspaceflight
creator of virtual planes
I could probably tell a long story of the background as to how I got here and why I designed this. But I'll try to keep it short.
I'd call my flying skill level beginner. Not to be confused with newbie. I can go through an entire battery without any crashes, but not every time. I don't stick to any sort of pattern while flying, I just fly around aimlessly and I'm not entirely sure I could hold a flawless, simple pattern.
I'd like to avoid breaking props or bending motor shafts as much as possible because I still do crash. I should say that I still make "newbie" mistakes while flying. Everybody crashes. I've broken way too many props and I have bent a motor shaft or two.
When I first started building, I used Flip Side brand foam board which is just like Elmer's brand. About twice the weight of Adam's (Dollar Tree) but is water resistant as is, has color on one side and white on the other, and is more durable. Here is an article I wrote when I first got my hands on some Dollar Tree so I could compare it to what I was using: http://www.flitetest.com/articles/comparing-foam-board
I want to go back to using Flip Side because it is better than Adam's in some ways. The downsides is the weight and that it's much harder to work with. But I think the advantages outweigh the disadvantages. Especially since I'm making my design with as little foam board as possible to keep the weight down.
In order to protect the props/motors, I'm doing what the Hobby Zone Duet did. http://www.flitetest.com/articles/beginner-indoor-planes-review
I didn't 3D model the power pods/motor mounts.
I'm going with a simple undercambered wing. I think I'm going to make a flat plate to mount power pods onto. But I'm going to glue the pods into place.
The thinking is that the wing tips and nose will hit the ground instead of the props. (I'll add landing gear so I don't break props with belly landings.)
I don't like the look of twin boom pusher planes. I was going to make a Bixler or Smash Drone type of plane, but I didn't like how tall the fuselage would have to be. I've never build/flew a twin engine before, but I love the idea of one. It's my understanding that torque roll doesn't exist with two motors (when using CCW and CW rotating props). So with two 8x4 props it will have more than enough get up and go without any torque roll. This just seems like the best route for me.
Today I bought two sheets of yellow Flip Side foam board, which is why I colored it yellow. It's the exact color scheme I'm going with. I think I'm buying all new motors and ESCs for this plane. Maybe even a new Tx. So I'm unsure when I'll actually get it done/flyable.
Considering all of the options, I think this is what's best for me. A 4 channel plane that is resistant to breaking props.
