Hi folks,
This relates to cutting out the plans.
Do you guys use spray adhesive to stick the plans to the Dollar Tree Foamboard?
If so, what do you recommend?
I've got some 3M 77 in an aerosol can somewhere but I'm pretty sure it won't peel off after cutting out the parts. Do you just leave it stuck on?
I tried just sticking the plans down with utility masking tape but didn't like that idea - tough to cut through and then the plan is no longer attached to the foamboard.
Do you guys run a thin film of hot glue over all exposed edges to prevent the paper backing from peeling off or will a coat of polyurethane do the trick.
Does this polyurethane support a top coat of water-based paint or only oil-based paint?
So many questions...
Cheers!
Cheers!
