Highflyer98
Hello,
I am getting back into the hobby, and I am trying to build a wing. I bought the SpeedyBee F405 Wing Mini and got it all setup with INAV. I got the reciever to work and I am able to control the servos. I can not for the life of me get the ESC to calibrate though, everytime I follow the steps I the esc just starts beeping every 2 seconds.
I broke out the multimeter and tested the esc terminals and was alarmed to find that there was only .3 ohms of resistance between the positive and negative terminals. I did not see any solder bridging the gap, and even after removing all of the solder I still had .3ohms of resistance.
I ordered a second of the same flight controllers from the same Amazon seller, and I just took the new one straight out of the box and tested it with my multimeter and found it also had .3 ohms of resistance between positive and negative esc terminals. Is this normal or did I get 2 out of a bad batch?
Thank you for your help!
