SR-71
I’d like to see a simple, mini and a master build of an SR-71 Blackbird some day. I imagine the mini would be pretty easy, the mini would be fast and the master series… awesome!
Yeah, I agree that that would be...
AWESOME!!!!😁
quorneng
Quite apart from any weight/wing area issues building a true scale EDF SR71 has a fundamental problem. The inlet "spike" occupies a huge proportion of the inlet area.
To keep a scale size spike would mean using substantial "cheat holes" to ensure the fan got sufficient air or use a much smaller size spike.
However by placing the fan right at the back of the nacelle in the convergent/divergent nozzle it might be possible for the total of all the scale inlets to provide sufficient air to the fan.
Just an idea.
L Edge
Just an idea.
Here is some food for thought.
Been done, but it is an ungodly logistical pain somewhere for not a lot of success, but sometimes you gotta scratch that itch. Can you fly a small plane suddenly going really darned fast? I cant.
L Edge
After dropping Shuttle and flying it down, worked on Bell rocket 1, where drop it from transport, let it fly down and across field, then hit D-12 rocket and pull it up and then glide back down.
Knew wing was not large enough for weight, so when nobody at field, very nervous( kept backing up) I fired it. Actually checked controls on way up(slower than my 200 mph Formula 1) and had a sharp landing slope.
L Edge
