1500 KV is a bit hot for a larger prop, you might be able to do that with a 9x4 or similar prop. You would have to look at the motor chart, see how much thrust it makes with recommended props.
The bushwhacker uses power pack C so the same motor as the other one, 2218 1100kv.
