I am planning a new RC scratchbuild and was wondering how do you control elevator on a T-tail? Do you use one of those flexible push rods to get to the tail? Thanks
Depending on the size of the plane.
Servo in the fin or a push rod angle to shift the force 90 degrees.. Cant find the item but i will try to sketch and if possible you will understand or someone will get a link to where you buy it.
Bent pushrods are not so precise but are used in smaller foamies.
or this http://www.v-eastonline.com/products/T%2dTail-bell-crank.html
I believe that you can also use a flexible push rod in a nylon sleeve that goes up through the inside of the vertical stabiliser - gliders use it all the time.
