Aura 5 lite v-tail trims
EvoRob
Went to maiden my eclipson cobra v-tail, applied elevator trim and only one servo was moving, but with stick movement, both surfaces move. I have the transmitter setup as a standard plane, all mixing rates etc is being handled by the aura 5 lite.
How do I get the Elevator trim on the transmitter to affect both servos providing elevator?
Thanks
If you are checking it when it is on the ground and not flying, make sure you are in manual/passthrough mode. If you are in auto leveling or gyro modes, the surfaces may not move the way you think they should.
