It looks like a decent kit for the price, but you will have to build it out. intermediate build skills -- epoxy layup to join the wings with cloth/tape, cutting servo bays and channels, mounting tails, linkages and electronics. You should be fine, and it should be good build practice, just know what you're getting into. 10h finish time is doable, but optimistic. There's a decent build-out thread over on
RCG which steps through the process. Keep in mind there are things you can do off that script that are a bit more work, but pay off in performance.
I'd highly recommend investing in "not bottom of the barrel" servos -- I've been running Hyperion ds09's , which run as low as $18-$22/ea...x4. These are cheap servos for what they are, but they perform very well. They can run 1s or 2s, so all depends what your chosen RX can handle as to whether you need a step up/down regulator. They also have a programmer module that's pretty cheap -- basic and a pain to get running on a PC, but will allow you to digitally recenter and adjust the throw over the DS09's 140 degree throw. All told that adds roughly $80-$100 to finish out to PNF. There is a slim analog servo, the ks47mg, that are thin enough to slip in the wings, but you'll probably value the extra throw and better performance of the ds09. Whatever you choose, don't pick a servo thicker than 9mm.
As far as handling, the airfoils she has are behind state of the art, but they're a good, well behaved set that should give you friendly performance. Should treat you well as you pick up the rythm of the launch. The wing is carbon and glass skin as opposed to Kevlar, so she's susceptible to some rather nasty dings and dents, so keep her away from trees, fences, shins and hands -- catch her by the pod or belly land. Don't try to catch her by the leading edge...or tail
Otherwise, dents and dings should be patchable with a little epoxy and carbon tow or cloth. Good practice in patching composites.
Oh, and plan on replacing that peg. It's fine to start, but once you throw with a nice one like Eitan's, you'll be spoiled. They run pretty cheap ($17, shipped, IIRC), but you'll have to wait for it to ship from Israel.
