mayan
@CarolineTyler that looks really really good.
Could you elaborate on that (for those of us (me) who might not be entirely sure of your meaning.... (i’ve Played with covering... once, but it was on foamboard.)Do not forget to cut the covering away before gluing it in place
Ah, makes perfect sense now! (Duh)..For pieces like the stabilizers that get covered first, and then glued onto the fuselage make certain you are gluing balsa to balsa! Cut away the covering in the spot where the pieces will touch, cause gluing onto covering seems OK in the workshop, but it inevitably fails in the air![]()
No more to stick together as I've broken it down to units that will be bolted together. The previous owner had heavily epoxyed the tail feathers to the tail and I've taken the trouble to freeing up all that and cleaning it up.For pieces like the stabilizers that get covered first, and then glued onto the fuselage make certain you are gluing balsa to balsa! Cut away the covering in the spot where the pieces will touch, cause gluing onto covering seems OK in the workshop, but it inevitably fails in the air![]()
I would use it on EPP foam planes maybe to make it smoother, but would not be bothered covering foamboard.Quick question about covering why would you use it on FB when FB can easily be painted on? Makes sense with balsa builds where they can act as part of the wing airfoil for example.
That’s also a good reason. Tried using a mask when painting?in my case it was laziness...have a problem with paint fumes (bad chest) so normally use wing tape for most of my builds !!
i had the covering film left over from my balsa days ,so gave it a try !!
Recently I laminated the wings on my $10 glider (regular styrofoam), I was amazed how much it stiffened up the wings, even without carbon fiber!if i need parts to be more sturdy i use laminating film
I expect a couple of weeks and it will be ready to fly like a phoenix.Come on, you can’t do this teasing we all want to see it fly.
No way. You can’t leave us on small fire for a couple of weeks ain’t letting that happen. I’ll be biting my nails till then and probably be left with no nails at all by thenI expect a couple of weeks and it will be ready to fly like a phoenix.![]()
I'll post some pictures of the mounting of the servos and progress on covering. These servos are massive compared to the ones we use in the typical FliteTest style planesNo way. You can’t leave us on small fire for a couple of weeks ain’t letting that happen. I’ll be biting my nails till then and probably be left with no nails at all by then.
I was going to ask what type/size servos a plane like that would takeThese servos are massive compared to the ones we use in the typical FliteTest style planes
I've gone with these... MG995 from Banggood. There was a good deal on buying four at the same time and I figured, why not, one may not be working on delivery.I was going to ask what type/size servos a plane like that would take
