Some of you guys were curious about the planes in the hanger so I've taken a couple of photos and I'll endeavour to give some explanations as well.
This is my motor glider in progress... there is an RC Cessna trainer behind and to the left and one of my top secret designs tucked away behind a sheet of foam board. The other plane is just a little something that my Father is almost done building...
Ok all joking aside.
First up - The playground:
First plane: VariEze
The VariEze is a little hotrod of a plane built entirely out of composites, so bluefoam, fiberglass and not much else. It's designed by one of the greats of aeronautical engineering, Mr Burt Rutan who is probably better know for Spaceship One and also designing and build the Voyager that flew around the world non stop with Gena Yeager and Dick Rutan as crew. It's a pretty impressive aircraft in it's own right and not only because of it's looks. It has a 100HP engine in it and will cruise at about 165mph with a top speed of around 200mph. It has a range of around 850 miles which was pretty impressive for the day, especially when you compare it to something like a Cessna 152 which has only 440 miles range and a max speed of 126mph, but had a much more powerful engine.
The VariEze had some drawbacks in the design, not the least being that it lands 'hot' or pretty quickly. As a homebuilt and having different pilots with different skill levels, Rutan wanted to build a plane that was both a performer and safe. The VariEze also has no storage space and can only carry two small to medium sized people, anyone of around 80kgs and over and it's essentially a single seater. It will carry 700pounds empty weight, so will 27 gallons of gas in it and two medium sized people, you're right on the limit which is not ideal in a small plane.
So - looks fantastic in the air and, even almost 40 years later is still an impressive plane.
The next progression from the VariEze for Burt Rutan was the LongEze. Larger than the Vari, it was built to address all the shortfalls of it's smaller sibling. It is a much less touchy plane to fly and although slightly slower (cruise speed of 144mph and top speed of 185mph) it has a vastly improved range of 2010 Miles (compared to the 850 Miles of the Vari). It could conceivably fly from one side of Australia to the other on one tank, or from Australia to New Zealand... I wouldn't consider it because it would mean sitting in the thing for 10hrs and I can't hold on for that long...
LongEze - it's a matter of months away from it's maiden
And you thought wiring an FPV plane was bad...
Obligitory brrrrrm noises here...
The other fun things?
One Rotoway Executive Chopper
Other things that you can't see
One Quickie:
One Solitaire Motor Glider
Both are also Rutan planes... you might see a trend here...
The others are an RV4, a Glassair and a Glastar but these are owned by other people so I can't give you more than cheeky glimpses at them!
I saved the best for last though...
This is the lawnmower
It's currently grounded due to starter issues but even if it would start it doesn't having any blades to mow anything with. It's range is classified as is it's top speed. I'll leave you to gaze in wonderment at its sleek lines and powerful stance... looks fast just sitting there doesn't it...
