flyinsparky
I made a Baby Baron that I couldn't ever really get flying like I wanted, so I pulled out the mini servos and put them into a sport wing for my Tiny Trainer. This was my first try using a 4 channel plane so I was excited. The build was pretty straightforward, I put in a new model into my transmitter and set it up for 4ch, made sure all the servos were going the right way. Went to fly it with the new wing and it pulled a HARD left and dove right into the ground. Bummer... she had been flying so amazingly. Patched her up a bit and tried again... Same thing! Then I realized the ailerons weren't going the direction I thought... weird. Reversed them and got it up in the air but it was really touchy and also the rudder was reversed, I hadn't noticed that before. Brought it down and reversed that servo. Once I got it back up in the air, I realized that I hadn't selected the correct model on my transmitter, which was why everything was wonky. Well that's a mistake I won't be making again.
So after a couple hard crashes the plane now flies really well, but it has started acting really strange. After getting it up in the air it flies for a minute, then the motor cuts out (still have servo control) and I get a lot of beeping. Tried throttle up/down, no motor response. Unplug and replug battery and everything seems fine for a minute of flying and then same thing. On the bench, I got some beeps while just using the servos... maybe not enough juice coming through the esc? It's a mt1806 motor with a BLHeli 12a esc. Anybody have ideas? I'll try soldering up a different esc and see if that helps.
Finally, I am wondering about the aileron servos... should I use a y-harness or extensions to my receiver and separate channels? I'm not planning on doing any differential, or flaps... (unless there is a good argument to try it.) Thanks!
