Tiny Trainer power pod template.
After making "my fair share" of power pods I decided I should make a 3D printed template. Should be self explanatory on how it works, the two sections that get cut and removed get cut most of the way with the template in place, then you can line up the edge and finish the cuts. The thickness is so that an Olfa razor knife can set a couple clicks out and wont cut through both sides of the paper.
Here is the link.
https://www.thingiverse.com/thing:3683915
My luck its already been done, if so I at least got the drawing practice.
