Well, I wired up an ESC, tightened up the prop nut, hooked up a servo tester...and it hovers!
I even managed to get the prop on the right way first try. These underslung motors always get me confused on rotation direction and prop mounting...but with my "Danus style thing" and singlecopter both using them I'm starting to get the hang of it finally.
Been trying to post photos since last night...but seems the forum isn't happy with me or just in general right now so not happening.
Plus...I'm getting pretty far off topic at this point so starting to think I should start a build thread for this thing now. It hovers quite nicely at about 25% throttle. I did have to switch from tape to hot glue to affix the skirt because above about 40% throttle it pulled the tape off and blew out the skirt. So now I'm really thinking about how to design some kind of clip to hold the skirt in so it's both removeable for maintenance and replaceable when worn.
Also thinking the 2204 motor and 5" prop are overkill for the lift. Probably would be fine with an 1806 and a 4" prop...but I don't have any 4" props and don't feel like cutting one down...and an 1806 with 5" prop probably isn't as efficient. But the way it is right now tying the lift and throttle motors together seems like it will result in blowing out the skirt quite often. So I'm leaning towards having the lift motor on it's own channel. (I can always rig up a TX mix to make it act like they're on the same channel but limit the max power on the lift fan.)
I did try pushing it around on various surfaces - a bit more lift throttle definitely helps on rougher less even surfaces. But still it zoomed around on uneven bricks, over piles of debris and my garden hose just as smooth as the tiny hoov does on smooth concrete. Didn't get to try grass yet...maybe at lunch today
