Yep, ours is a e010...I got a few of them on sale for $12 each shipped after thanksgiving 2016
I personally prefer the soldered motors since it's lighter and on something this small it sure seems that both as a quad and as a hoov saving weight makes a big difference.
Speaking of the hoov....I just did a little upgrade on ours.
Last night I sat down to watch some youtube and saw that Tom Stanton had made a 3D printed hovercraft with a 2204 motor:
Neat design and I do want a bigger hovercraft...but I don't want to spend that long printing it. I really want a separate lift motor, and I'd rather have either dual fans or dual rudders for better control (though his triangular rudder seemed to work quite well!)
After I watched it Youtube suggested Peter Sripol's hovercraft build from last February:
Which I have to admit I had completely forgotten about. But again...I don't want to do that much printing...
But after that one Youtube suggested the one Peter built while he was with FT:
And after watching all three I started rethinking the skirt I had made on our tiny hoov:
It was a real quick and dirty attempt at a skirt. And very poorly thought out. Which I knew when I was doing it. It didn't seem like it would hold in much air but it only took me 5 minutes and did make an improvement over some surfaces.
But knew I could do better. And after watching those three videos last night I had a good idea how to do better. So I fired up onshape and did a little skecthing:
https://cad.onshape.com/documents/b...7edf245f2f558b6307/e/0338feea5bc9cc8c6d86fb65
While I waited on my hot glue gun to warm up I loaded it in estlcam:
Realized I had made a tiny mistake in the drawing...but was able to correct it in CAM by creating the cut path manually instead of using the auto tool.
Fired up the needle cutter and before my glue gun was even warm enough to use I had this:
Test fit looked good...without even trying I actually wound up matching up to the motor mounts with my center holes:
Since my glue gun still wasn't quite hot enough I decided to also make a template for cutting the skirt. I just took the outline of the skirt retainer and enlarged it 130% (Though having tried this now I'd go 140% or maybe even 150% if I do it again) then cut that out with the needle cutter:
Ignore the mess in the upper right....this was some foam I'd "ruined" with a mistake on my machine previously and figured I'd re-use it for this non-structural part.
By now my hot glue gun had warmed up so I put a little bit around the inside of the center section of the retainer and glued it down to a shopping bag - then put the cutting template on:
Then using the techniques Peter explained with his two hovercraft I glued the skirt up, glued the retainer to the craft, and cut out the two center holes for lift air:
This works MUCH better than my previous skirt attempt! I can now transition from our tile floor to the rug about 90% of the time. Outside it doesn't pick up dirt like my previous attempt did. And it can now move over dirt and gravel far better. Still can't get over grass...but doesn't get hung up on as many cracks and gaps in the pavement.
Top speed is reduced a bit. It's probably partly the extra drag, and partly the extra weight...but...one of our lift motors is also dying so that likely plays a role as well.
You can actually see the skirt inflate and the craft lift up now with this. However...the skirt doesn't inflate as well as I'd like. As I mentioned previously it should be a little bit bigger than I made it. Also i should have left more holes along the front for air to inflate the skirt as that part is both less baggy and what is there doesn't inflate well - and that's the bit that would really help it over bumps best. I'd probably also modify the center section a bit so more air can get into the cushion easier.
The big problem is durability:
After only a pack and a half or so of hooving the skirt is showing major signs of damage already
I may try a garbage bag next...just not sure what else I may have around that would be light but strong for this use.
If you have an original hoov (I don't know if this would fit the FT version or not) and want to give it a try the Onshape link above is public so you can duplicate it and modify all you want....or just right click on the sketch feature and select export to get a DXF. Or to make it really easy I uploaded the DXF to my google drive where I also have the original hoov plans converted to DXF and setup in estlcam for CNC:
https://drive.google.com/open?id=1OJNH5VJLjsLLE05RE_Rumx-KN34DW2i9
Guess I better go track down some replacement motors....
Or start drawing up a bigger one. I'm leaning towards an 1806 lift motor with a 2204 drive motor and dual rudders both sized for 5" blades. But I also have some spare 1103 motors that may make for a fun smaller craft...but I'm thinking 5" blades sounds like the most fun....
