mayan
Thanks!
Thanks!
Don't check your motors or wiring before you actually fly with your props on. Even the smallest motor can give you a VERY bad day
Always disconnect power in your plane when you're done flying. Falling or tripping can lead to problems mentioned before.
How about tips of flying in populated areas? you probably have much to share about thatNot much more to add from me, if I'm honest. You've got some great folks with a whole lot of knowledge to chime in already.
If you need any help with stabilized LemonRXes or want some hints or tips for flying floatplanes/flying boats, I could share those, but as they aren't in the spirit of this post, I'll keep them to myself for now.![]()
I'm waiting for my change back.😁😎
How about tips of flying in populated areas? you probably have much to share about that.
You see short but to the pointShort answer: don't
Longer answer: don't until you know what you're doing.
Word!I guess I should clarify here.
If you've seen any of my videos, you can see that I live in a large neighborhood that has several ponds/lakes scattered throughout it. The largest lake is basically in my backyard and it has a common area that is a grassy field the leads right down to the water. The field is probably 100 square meters or so, and is ringed by young trees with houses (including my own) beyond that.
In general, I do not advocate flying near other people or their property. It is very easy to become "that guy" that gives all us hobbyists a bad name by causing some sort of injury or damaging someone's property.
That being said, I have chosen to accept the risks of flying in my neighborhood as long as I am willing to stick to a few self-imposed rules:
1. No flying in extremely windy weather. I need to be confident that I have control of the airplane at all times.
2. No overly large or noisy aircraft. Larger aircraft cause more damage when they hit things, and loud ones are sure to attract the wrong kind of attention.
3. As much as possible, try to fly over the water, and limit flight vectors that aim towards people or property.
4. No flying and specifically no takeoffs or landings when the common area is being used by other people.
Even with that being said, I need to reiterate that I do not advocate anyone else flying in their neighborhood. It only takes a second to get yourself into some pretty serious trouble, not to mention it would be hard to live with yourself if you hurt someone with one of your planes.
Recently had the fear that my Mini Might Mini TT flew into someones house, someone I don't and probably wouldn't have had the courage to go ask for it. Luckily I managed to crash it into a tree in a abanded properity.Agreed. There are only 2 times I've flown in my neighborhood:
1) I was flying my Inductrix outside, in front of me, going around the tree in my parents' front yard, and bringing it back around. I wasn't getting crazy with it, because it was starting to get windy, and the tree has lots of little branches that hang down and like to grab small things like drones out of the air and "eat" them.
2) I was flying my Inductrix drone indoors, in my home. If I crash into anything, it's damaging my home, my stuff, and I'm generally not flying in a crazy fast, out of control manner.
It's just not wise to fly in neighborhoods if you can help it. Having to explain to your neighbors why you need to get on the roof of their house, or into their backyard because your plane went down on the other side of the fence? I kinda gave that up when they said they were going to keep the ball that ended up in their yard. LOL
