T tramsgar Senior Member Aug 29, 2013 #3 Aug 29, 2013 #3 That looks fantastic! Really excited to see it fly!
xuzme720 Dedicated foam bender Mentor Aug 29, 2013 #4 Aug 29, 2013 #4 Wow! So nice! Have you flown it yet and how does it fly, if you have?
OmarEL Junior Member Aug 30, 2013 #5 Aug 30, 2013 #5 i have not figure the angle that the motor should be in order to avoid the down effect.
xuzme720 Dedicated foam bender Mentor Aug 30, 2013 #7 Aug 30, 2013 #7 Try a few degrees, maybe 2 or 3 degrees to start.
CrashRecovery I'm a care bear...Really? Mentor Aug 30, 2013 #8 Aug 30, 2013 #8 Wow!!!!!!! You got some skills bud. I have to agree with xuzme on the degrees. If anything it looks like it will be tail heavy. Have you found the cg yet? With it being tail heave its going to be crazy to fly.
T tramsgar Senior Member Aug 30, 2013 #9 Aug 30, 2013 #9 OmarEL said: i have not figure the angle that the motor should be in order to avoid the down effect. Click to expand... Leading scientists say that the thrust vector should pierce the CoG.
