Ok, not really but if it gets you to look then good.
I had an idea to try on a Dragonfly tricopter. Instead of mounting the two engines on the center spars in the inverted position what if they were mounted horizontally to supply only forward and reverse thrust? They could also be used to rotate the copter around its center axis.
I don't know if this has been tried or not or if it would work but if it did I think it would give you a very fast and responsive craft.
LSpitz
LSpitz
