Transmitter for beginners
Hughbertis
Hi Guys and Girls,
I am looking to get my first transmitter. I want to fly both BNF fixed wing and multi rotors. Is there a good transmitter I can use for both. Spectrum seems to be the brand that is best for aircraft but I am not sure they are good for multi rotors.
Any advice would be great 🤔
H
Grifflyer
WWII fanatic
Hi Guys and Girls,
Any advice would be great 樂
H
the only way you can do most BNF aircraft is with mostly spektrum which works with multirotors, but alternatively you could get for less $ a Flysky fs-i6 which does quads like gremlins up to 5 inch racers, but if you do get this one it might not work well around a lot of other people and you won't be able to do telemetry.
Geeto67
Posting Elsewhere
I have a Spectrum DX5 and DX6. here are my thoughts:
DX5: Spectrum doesn't make this one anymore but their replacement for it is the DXe. It's a basic transmitter and the price reflects it. IF you were budget minded this will technically do everything you need to do at a bare minimum. At $60 it's a pretty good deal, I use it almost exclusively for BNF foamies, but it could be used for very basic multi rotor copters. This is still way more an advanced transmitter than we used to use back in the days of swapping crystals and $200+ futabas and at a fraction of the cost and people flew giant, sometimes complex airplanes with those. The downside to it is that it has no storage memory. You bind it to the airplane/copter every time you use it, which means you have to memorize any trim settings for your airplanes and manually set them or just fly and re-trim every time. If you have 1 or 2 airplanes/copters not really an issue, but if you have 10 it might be something.
DX6e: this I think is the cheapest Spectrum that has a programmable memory. At roughly $150 it's twice the price of the DXe, but there is a reason. The transmitter lets you store settings for particular aircraft including trim and you can just toggle back and forth. For some airplanes you don't even have to rebind the transmitter. A great example for this for me is I have a 3 channel airplane that I use the aileron sick for rudder control (since it doesn't have ailerons) and have it trimmed accordingly, and I have 4 channel cub that is setup completely different and even has the elevator reversed because of how the servo is mounted. Switching between the two is just a matter of changing the plane in the menu, no switches to forget to flip or rebinding necessary.
A lot of the really expensive copters sometimes have their own remotes because of the camera controls and view screens. You want to think about the type of multi-rotor you really want to fly. For me I just want to use a quad copter to do 1080p+ video for my other hobbies so I wouldn't even want my DX6 for that, I'd want, for example, whatever is paired with the DJ Phantom because it has video output ports and it's own screen and I would only want to use it for that.
Bricks
Depending on your budget a Spektrum DX6 black do will all you want and more. A good used DX6 can be had for $100- $140. I am actually selling my DX6 Gen 2 all updated to the latest software I picked a DX9 is the only reason for selling the 6. PM me if you are interested.
sprzout
Knower of useless information
My $0.02 on this as well, as I fly both fixed wing and multirotor:
The preferred transmitter for multirotor is FrSky radios. From what I understand, they are a more robust radio for less cost. That said, they're a pain to get set up initially, as they have a steep learning curve to get things set up. I also don't see many people flying fixed wing using FrSky transmitters, at least, not here in the San Diego area; most are either Spektrum or Futaba.
I bought a Dx6 Gen 2, brand new, for $200 when I got my Blade Conspiracy in April of this year. Turns out this was a great purchase, for several reasons:
1) My father bought an Apprentice 15e; I was able to fly it by simply making a copy of his plane's settings, straight from his transmitter, and copying it onto my SD card, which I then put into my transmitter and uploaded. No need for a bind connector on the receiver, no setting of trim, or throw, or anything like that - it was all configured to fly the same way he did.
2) The radio can store settings for up to 250 different planes. This is a LOT, but it's possible you'll fill that up. How so? Well, if you share planes, like I mentioned above, you'll get all of your buddy's planes in your transmitter when you do the chip copy. If he's got 5 different planes from your 5 planes, boom, you've got 10 planes you can fly now. In addition, if you have a wireless USB dongle that you use to connect your transmitter to your computer (I have one, and so does my dad) that takes up another plane setting. Sure, you can just re-bind planes/drones every time you go to fly, but if the receiver's sealed inside your plane (like I have on my Sea Duck, as I want to keep it waterproof), re-binding every single time you go to fly is a pain in the butt.
3) Lots of people at my field fly with Spektrum. Now, yes, this is a bit of peer pressure to go with what everyone else has, but the plus with this is that if you need help getting it set up, the guys at the field who have your radio (or a similar radio) can show you how to get in to settings to do things like differential thrust with a twin engine setup. Support from friends is another big reason why I went with the Spektrum over the FrSky radios.
All this said, there are some wonderful radios out there that are not Spektrum. Futaba, HiTec, Graupner, FlySky - they all are comparable. But, if you want to buy a BNF kit from most local hobby stores, odds are it's going to have a Spektrum receiver and be ready to configure to that type of transmitter as soon as you take it out of the box. It's a "sufficient for most" radio. If you can pick up a used Dx6 (and I would recommend the Dx6 over the Dx6i because of the larger amount of planes you can store), it's worth the purchase, in my book. Yes, it's more expensive than the DXe that Geeto referenced, but that is a VERY basic radio, and if you wish to tune it, you have to have either a special Bluetooth module to sync up to your phone or a cable to connect to your PC to configure it. It's usable, yes - but honestly, it's a LOT easier to go scrolling through your radio to change settings than to have to hunt down a cable to connect every time you want to change planes.
French
Construire Voler S'écraser Répéter
I love my FrSky Q X7 at $110 with <$20 aerial receivers, but it done not BNF to much natively. You can add on a $40 external transmitter that doesn&#8217;t ~40 protocols, but that&#8217;s not the best solution. Sounds like Spektrum is where you need to be.
JimCR120
Got Lobstah?
Site Moderator
Generally you will find many Spektrum users and even more Taranis fans. The former boasting excellent customer service and the latter more ways of modification. I am a Spektrum user and fly fixed wing and multirotor.
There is another player on the market now, the Jumper T8SG which boasts multiprotocol capability. At about $70 it seems to be a competitive player that I hope will drive up qualtiy and drive down prices.
I recommend you focus on those 3 radio directions.
How much are you thinking of spending?
I notice you are new to the forum. How about some more about yourself like where you fly and your experience in the hobby.
Welcome to the forum.
&#8212;Jim
