Even though I have bound my radio to my receiver via cleanflight CLI my stick movements do not show up under the receiver tab in cleanflight.
My set up:
Transmitter: Spektrum DX6
Receiver: Lemon DSMX satellite RX
FC: SPF3 with betaflight 3.0 hex file
ESC: Kiss 24A
It appears I have successfully bound the DX6 to the satellite using the CLI in cleanflight.
I used set spektrum_sat_bind=7 (DSMX 1024bit/22ms)
Channel map is on TAER1234 (spektrum)
I have enabled serial RX on UART3 (see photo)
However I'm not sure if I should have activated the serial RX on UART2 or UART3 or even if this is relevant to my problem.
Under the "configuration" tab I have set the serial receiver provider to SPEKTRUM1024 (see photo)
Could this be a dud board? Is there something I'm missing? Firmware issue?
I'm absolutely bamboozled here and any help would be greatly appreciated.
My set up:
ESC: Kiss 24A
