I decided to swap my APM board for a Naze32 (afroMini) to see what the difference would be. The APM flys just fine on this tri, so the problem isn't with the frame. With the Naze I am getting a lot of servo jitter. Even wile sitting on the table, twisting the model causes the servo to go into uncontrollable jitter. While flying, the servo get's into a jitter that's getting faster and faster, and faster, uncontrollably. I tried playing with PIDs with no luck. The only thing that helps is getting the P all the way to 1, but that makes the yaw very twitchy, and the jitter is still there, stressing out the servo a lot.
I know on other flight controllers there is a low pass filter for servo input, but I can not find the same on Naze32. Any ideas?
If you are flying a smaller tri with naze, could you also tell me your PIDs. Thanks!
- Bogdan
- Bogdan
