Today I finished my build of the Tricopter V3 with integrated Naze32 from RCExplorer. Beautiful machine. Buttery video, lovely to fly... except: the yaw drifting. Now David mentions this in his setup video:
Set I and D gains to zero, go fly it and compensate the yaw drift with a trim until it's gone. Go back to cleanflight and transfer the offset value from 1500 in the yaw channel to the midpoint in the servo tab. Re-enter the I/D values, delete the trim on the tx.
This I did. Problem is: To get rid of the yaw my offset value is almost 200! The motor on the tilt is angled at about 25 degrees. Is that normal?
Of course I put the servo in it's neutral position before mounting it. In doing so it may have been turned by 2-3 degrees but by far not that much.
This being my first Tri I'm not sure whether this normal or not. David does mention that if the values are extreme the servo may have to be re-positioned. But if the copter only stays straight with the back motor angled that much, what difference would that make?
Furthermore: I don't if it's related but CF calls for all 3 motors spinning CCW. David suggests to have the front left to spin CW. Did this as well...
Any help would appreciated! Thanks!
