Help! Need help setting up a tricopter
NEEBS
I was wondering if anyone here has experience making tricopters and knows how to set up the Matek f405-std flight controller on Betaflight. I've set up the motors and servos in this order:
Right motor: S3
Left Motor: S4
Rear Motor: S1
Servo: S2
I think my first mistake is that the Servo should actually be wired to S1. I'm basing my statement off of this thread: https://fpv-community.de/threads/tricopter-mit-betaflight-4-0-und-matek-f405-ctr.85022/ where someone used the f405-ctr and stated that S2,3, and 4 use the same timing. But on top of that I am completely oblivious as to programming the FC properly. Any help would be appreciated. Thanks!
Side note: I'm using S5 for FrSky R-XSR. Maybe I can wire the signal wire of the servo to S6?
NEEBS
Update: I've figured a few things out!
I put the servo feedback wire on S5, but I am not sure where the power belongs... for now I have wired them on the (+) and (-) next to the S1 pad. I really do not know what I am doing
In the CLI tab, I assigned motor 2(top right) to C08(S3), Motor 3(top left) to C09(S4) and motor 1 (rear, I also rewired motor 1-->) to C07(S2). Furthermore, Servo 1 gets assigned to A15.
I relocated the Fr Sky wire to TX2. Matek states that it has a built in inverter but I am not sure if anything needs to be done there. Also, when I attempt to turn on Smartport on Uart 2, the whole row becomes disabled.
Motor 2 kept spinning the wrong way so I looked it up and I learned that I can use blheli suite to reverse the direciton of the motor.
On betaflight, the servo responds on servo 6 in the servo tab but I still cannot get it moving. When I initially started working on this, the servo was wired to S1 and it was moving but it only moved in one direction and eventually it stopped moving entirely. I am starting to consider that I broke it : (
To sum it up, I have got the motors working but not the servo.
