Little_Raven
Hey all so I'm looking at getting a brushless motor and esc pack from amazon and here are the stats
DJI F450 F550 TAROT FY450 FY550 Quadcopter FPV PartA2212 motor:
KV: 1000
Max Efficiency: 80%
Max Efficiency Current: 4-10A (>75%)
Current Capacity: 12A/ 60s
No Load Current @ 10V: 0.5A
No. Of Cells: 2-3 Li-Poly
Motor Dimensions: Φ27.5* 30mm
Shaft Diameter: Φ3.17mm
30A brushless ESC:
Output: Continuous 30A, Burst 40A up to 10 Secs.
Input Voltage: 2-4 cells lithium battery or 5-12 cells NiCd/NIMh battery.
BEC: 2A / 5V (Linear mode).
Max Speed: 210,000rpm for 2 Poles BLM, 70,000rpm for 6 poles BLM, 35,000rpm for 12 poles BLM. (BLM: BrushLess Motor)
1045 Propellers:
Diameter of Shaft: 6.0mm
Adjustable by hole adapter (3mm, 3.2mm, 4mm, 5mm, 6mm, 6.35mm, 7.95mm)
Thickness of center: 9.7mm
Weight: 15 gram/ pair
Recommended wheelbase: 550mm - 700mm
So as I understand these stats it would call for something like this.
Turnigy Brand Lithium Polymer (LiPo)
2 Cell (2S1P) 7.4 volts
1000MAH
20C constant discharge rate
(30C burst discharge rate)
with JST Plug
If anyone could let me know or point me to some appropriate resources to better understand these things. I would really appreciate it. Also would this be an appropriate setup for mini arrow, sparrow, or tiny trainer? I'm having a hard time understanding motor power and what is appropriate for the different planes.
KV: 1000
Max Efficiency: 80%
30A brushless ESC:
1045 Propellers:
1000MAH
with JST Plug
