Mustang7302
Ordered up parts to build a FT Duster for the wife last week (Thursday) and the powerplant parts came in yesterday from the Hobby King US Warehouse. Wanted to do a watt and current test on the bench for this combination of parts so I got the 3.5mm female bullet connectors soldered to the motor side and a male XT60 connector soldered to the battery side of the ESC. Once all of the electronic connections were ready, I mounted the motor to the end of a 1/2" square dowel (the same used for the AnyCopter booms) and clamped it down to the edge of the bench with the motor hanging off just far enough for the prop wash to clear the surface of the bench. Bound a spare receiver to the transmitter, perform a throttle calibration, and we're off to see how much power is pulled with the trusty watt meter.
Power Source: 1,300mAh 3S 20C LiPo Battery @ 12.6V
Brushless Motor: Turnigy D2822/14 1450KV 160W
Brushless ESC: HobbyKing Blue Series 20A ESC
Propeller: Master Airscrew 7x5E Propeller
Watts @ WOT: 135
Amps @ WOT: 12
The power made is in the Park 370 to Park 400 range of motors, which is perfect for the bulkier swappable planes (Baby Blender, Cruiser, Spitfire, 3D, Versa, Racer, and Duster). For less than $19 plus servos and shipping, this combination seems a good balance of power for the dollar. Once the Duster is in the air I will provide further feedback.
I also wanted to bench test the run time of this combination to get an estimate of how long to set the flight timer for. Ran the motor at 50% throttle and monitored the watt meter for battery consumption:
Start of "Flight": 35 watts of power at 3 amps
8 Minutes into "Flight": 30 watts of power at 2.5 amps; 350mAh of battery consumed
16 Minutes into "Flight": 27 watts of power at 2.4 amps; 700mAh of battery consumed
24 Minutes into "Flight": 26 watts of power at 2.4 amps; 1,000mAh of battery consumed
26 Minutes into "Flight": Battery alarm going off at 3.3v per cell; 1,100mAh battery consumed
Gentle flying could see as much as 25 minutes of flight time with this combination, but I expect normal flying (fighting wind, landings and take offs, moderate acrobatic, ect.) should run for roughly 15 minutes.
Clear skies and soft landings!
Watts @ WOT: 135
Amps @ WOT: 12
