How much weight can these packs handle?
boogieloo Active member Oct 25, 2021 #2 Look at the model specs on where you are ordering or take on Pack c or b. Then measure what you are doing or need. Pack C twin edition has two ESC engines. Then measure what you want to build. Take it from there. Sorry for so late. I hope this helps. Last edited: Oct 25, 2021
Matthewdupreez Legendary member Oct 27, 2021 #3 Maurice Butler said: How much weight can these packs handle? Click to expand... Well considering that each motor gives approx 1kg thrust.. I wouldn't recommend a model weighing over 2kgs. For Power pack C.. For Power pack B, a model not over 1.6kgs
Matthewdupreez Legendary member Oct 27, 2021 #4 Matthewdupreez said: Well considering that each motor gives approx 1kg thrust.. I wouldn't recommend a model weighing over 2kgs. For Power pack C.. For Power pack B, a model not over 1.6kgs Click to expand... This is for the twin setups.
AIRFORGE Make It Fly! Moderator Oct 27, 2021 #5 Matthewdupreez said: This is for the twin setups. Click to expand... Those #'s are for the twins, Matthew.
Matthewdupreez Legendary member Oct 27, 2021 #6 Addicted said: Those #'s are for the twins, Matthew. Click to expand... Yes... I stated that in my post
Piotrsko Legendary member Oct 28, 2021 #7 The C twins derate the thrust? My single is good for 4lbs thrust on a 10 4.5 prop
Matthewdupreez Legendary member Oct 28, 2021 #8 Piotrsko said: The C twins derate the thrust? My single is good for 4lbs thrust on a 10 4.5 prop Click to expand... I was just looking at the specs for a 2218 1250 kV motor
