VIFLY ShortSaver - New Generation Smoke Stopper
Current smoke stoppers in market are all automative light-bulb or resettable fuse, both of them have some potential risk. VIFLY ShortSaver is a different one, it is electronic fuse.
1. Other smoke stoppers just limit not stop the current flow, the leakage current may still damage your components. VIFLY ShortSaver is a different smoke stopper that adopts the electronic fuse to completely cut off the current into your RC build if a short circuit or wiring mistake is detected.
2. VIFLY ShortSaver would turn off the power to a device that drew in excess of the switchable 1A or 2A threshold within just 10ms. It is far more effective than the old way of using light-bulb or resetting fuse. The shorter the protection time, the safer your build will be as something make break by the time the fuse trips.
For more details, https://www.viflydrone.com/smokestopper.html
#2
sounds interesting but are we introducing just one more electronic part that will fail at some point, .power consumption how much flight time will loose.. dimensions? weight is always a concern........anyone use these for any length of time.
Troll Spammer
#4
Smokestoppers are meant for bench use, not for in the air. When you do your initial setup and checks after plugging everything in, you use it to prevent a short, or bad gear from "letting the smoke out" of your gear, or potentially letting the smoke out of your battery. I think these "smart" stoppers are a bit of overkill. A properly sized incandescent bulb is not going to let any more current through.
I added a switch to my bulb type for ease of turning the power on and off.
thanks for that..........I have no need for this
Troll Spammer
#6
This is named a "short saver".... So basically just trips. The nice thing about using a bulb is you can see the bulb glow below the "trip point" and know you may have other issues going on....
PsyBorg
Wake up! Time to fly!
#7
Here is mine in actual use so you can see how it works and what important information a blinking bulb can divulge. (starts about the 16 minute mark for just the smoke stopper stuff)
#8
This video clearly shows how VIFLY ShortSaver can stop your build going up in smoke! It is a must-have accessory on your work bench.
#9
This is a comparison video with other smoke stoppers like the light-bulb or resettable fuse. After checking the video, you will know why VIFLY E-Fuse is better than others.
#11
Our ShortSaver V2 has also added the power switch, easier for binding receivers.
#12
"A smoke stopper is an essential tool for protecting your quad from damage. But until now, the light-bulb smoke stoppers were less than ideal. The ViFly ShortSaver is the smoke stopper you always wanted. It's small. It supports up to 6S voltage. And it uses e-fuses (not polyfuses) so when it shuts off, it really shuts off (and it doesn't light on fire). " ------- Review from Joshua Bardwell
PsyBorg
#13
Well like Bardwell says.. its kinda moot if you build big quads and it trips under normal conditions. Thats why I like my bulb set up. I can watch the flashing and tell that things are booting properly or if I get a solid light I know I haz issues. Just like in my video above. I did not know I would get beep codes after power up with no receiver powered up as I tested only the drive train on first test.
That said the product does its job well so I am in no way putting it down. For new builders smoke stoppers in any form is a must.
I just prefer the extra knowledge I get from the blinky blinky. Add that kind of functionality it your product and I am there. Until then Ill stick with my trusty 1157 bulb.
