Ok, not sure why, but the rudder servo keeps coming loose. To fix this, I'm gonna put a wooden floor in the plane (which ironically actually existed). She won't come loose after that!
It looks like you are using an ft a pack or 5" drone motor, and I don't think they can handle a 9" prop. what specs are the motor, like stator size and kv.
It's a Power Pack F, and I already tried a 9" prop on the Nieuport, and it had plenty of power. Besides, a 6" prop is not the correct scale. I mentioned this earlier, haven't you been following along?
Alrighty! Got the engine mounted, the prop attached, elevator servo is secure, glued the cockpit/firewall in, & set up the transmitter to reverse most of the stuff.
I have been following along, and I am not talking about power. What I am trying to say is that the f pack was never meant to handle a 9" prop, and even though it isn't scale, a 6" prop would be safer in general for the motor and esc. After that, its all up to you.
oic.....Well, I never saw such documentation, and admittedly, I may have overlooked it, but I think I asked some FT guys in the past & they said it was ok.
Yes the F pack can handle it, sorta, just take your hand and feel if it is hot after a flight, if not, great! Otherwise I suggest getting a smaller prop or a bigger motor, if you have the money I would just get a B pack because it will be more responsive then the F
what I meant is the connector that joins the two baterries, is it in series or parrallel, if it is in series then you cant use it. if it is in parrallel, you can
