Solved Whizzing servo
Thanks. I will try metal servo for the next build for now i will try and fix the raceršŸ‘ And yeah it has no resistance on it. Got to take it out😐
I contacted the place to see if they will be getting them in soon:) I hope so because they are the cheapest place I have found to get them! (I think I ran there supplies out)
Okay, so they got back to me and they said they don't know if they will be restocking them soon or not, but they are switching over more to Emax servos for higher quality. (some are digital too which is another plus!) they are a bit more but I am sure they are great quality!
Hate to spoil the thought, but, all servos today are digital PWM controlled or even numeric string positioning (still pwm however). Been that way since about 1972. I have some that aren't, but they are similar to bar of hand soap size and weight and older than me
Actually there are both digital and analog servos, the digital ones are much more precise.
Digital starts as analog and is converted to digital before sending to the goggles/RX. The process of converting to digital increases latency but allows for a clearer image quality. If there is significant signal drop out, video can be completely lost until signal is regained while video quality remains clear when you have signal.
Analog does not get converted to digital but still gets processed before being sent to the goggles/RX. Better latency than digital. More prone to interference. When there is interference, it will be seen in the goggles as static, discoloration, blurring, etc., but you will still have video in most situations. Analog is relatively lighter and cheaper. Most whoop/quad racers use analog because of the low weight and low latency.
As Litterbug shows, analog can provide very good quality vid.
Uh, we are talking about servos :)
Hex23
Not a cheapo servo fan.. if you have access to the bottom screws you could disassemble while still in the plane and replace the gears or whole assembly with new bottom assembly. Have had the top gear mounts break in a crash, but then the fuse was torn up badly also
I do not have access on it. I had to cut out square fb into the wing. I replaced it the other day and maiden it. Didnt fly that faršŸ˜… i used 1400kv motor. 8060prop. And 3s 2200mah. If feels underpowered. Maybe ill try to go 9045prop to a 1400mv motor🫔
Man! so frustrating! Hope your next maiden goes better!
Or a 1045 prop.
Hello guys. Its me again. So i just finished building ft racer and just waiting for a clear day for maiden. I was doing some tests then my right aileron just start whizzing and i lost control in it. Is it broken or can i fix it without opening the wing?
This is my electronics
1400kv motor
40a esc
Flysky 6ch rx with byme A gyro
2200mah 3s
4x 9g servos with the ailerons connected to Y cable
I had similar problem before this build, (also on the ailerons) where the servo just start making noise and then give up. It still has power in it cuz when i input on the tx it still makes a sound like it was trying to move. I will attach videos and a pic of the servos that i own.
Here are some good servos I was wrong about Mg90S's it must have been cheapies of those that I bought on Ebay because my brother got some today from Amazon and they were all metal gear.
