PierreFromBelgium
Foam Board FPV ADDICT
Hi guys,
To share (care) my windbox addiction, here is a topic of the "Windbox USB flight joystick ground station" from OPUAC :
"Windbox is a remote control system instead of the traditional mode. With the Windbox, USB flight joystick, USB gamepad, steering wheel, and other plug and play USB peripherals can be used to remote control fixed-wing model aircrafts, quadrotors, toy cars and boats. You will get close to the real fight experience. This product contains a ground station box, and an 8/10/12-channel 2.4G receiver."
I joined the WindboxManualV3_EN.pdf in attachment.
Firstable, really sorry for my pooring english in writing
Now, I am going to share you my modifications / improvements which I made for my windbox, according to my evolution and quad/planes I began to pilot.
First, two vids to see it in action :
Sorry, no more sound here...
More vids on my channel : https://www.youtube.com/user/PierreFromBelgium
Here is the first version: a kind of writing desk on which I settled the windbox in a wood structure, relatively solid. In the time I wished a portable system to allow to transport it easily and to pilot it up. The problem of this version was in the location of the windbox: the signal of the antenna was cut from time to time by the foot of my screen. So I decided to put the windbox in front of the station control.
So here was the second version which was relatively interesting in its use because better balanced and especially a better reliability in the use :
I am never happy with anything...
or maybe I like building and improving things permanently. As the previous configuration was good but relatively heavy, I have quickly began to have pain in the neck. So...next :
So the third version : a pilot sit (in theory) in a cockpit and especially it is much more comfortable to pilot well. Thus I have to fit out this seated system but not anymore transportable...
Previously, I was mainly flying quadcopters so I changed my joystick to get a more DPI accurate one, a Thrustmaster. But the main reason was especially to get a smaller trhottle, to be able to put gas to min and max more quickly. For the position, the simplest (and thus effective) was to take a normal chair with which I put the windbox on my legs
In the use, I fast understood that the receivers of the windbox were not at all reliable, too big and too expensive. As there was a PPM out, I bought a FrSky module with 4 receivers compatible without the telemetry. Thus I built a case in foam board to assemble the whole and enhance reliability on the long term :
And in the end (final), as I began to pilot more planes than quadcopters, I decided to return to my good old " x52 pro " :
Here is roughly the summary of these last 12 months in the course of which I did not stop piloting with my windbox in fpv.
My actual flying/sitting position :
If you have any questions, it will be a pleasure to answer you by trying to make a minimum of spelling mistakes
