Hutch Bunch Rc
This is my WW1 based biplane.
I used a few pictures of a Martin Mb1 bomber for reference.
I sadly don’t really have a whole lot of pictures of the build but here is what I have.
This is the early fuselage stage, basically a box with a rounded nose, the bottom of the nose opens up to a battery hatch for a 2200 3s.
The wings are relatively simple they are a flite test style and they each have a double foam spar with a 36” piece of 3/8 square spruce dowel. think the bottom wing is 52” and the top wing is 54”, the chord is 7”. The ailerons are only on the bottom wing.
Then I got the top wing all situated and the landing gear figured out, they curve around in a C shape and then glue onto some plywood.
Definitely needed this guy!
Last was the Nacelles, they were pretty easy, a box with a plywood firewall, the motor angles were pretty much a eyeball guess, everything on this plane was and eyeball guess really.
Here she is sitting next to my scratch built ugly stick.
Specs:
Top wingspan is 54”
Bottom wingspan is 52”
The chord is 7”
The fuselage length around 43”
Weight is around 2 1/2 pounds with the 2200 battery
Electronics: (Mostly bought off of value hobbies)
For motors I am using x2 flash hobbies 2830 1400kv motors, they each have over 700g of thrust and put out around 200 watts each, this is with a 3s and a 8x6 prop I think. This amount of power is enough, but the plane is very slow and sluggish.
https://www.flashhobby.com/index.php?id=3484
Esc:
I just used a few hobby king Skywalker 40a escs I had laying around, they are y’ed together for the receiver connection, one of the power leads is removed from one esc so there isn’t 2 BEC’s trying to power the receiver. Since there is only one battery, it is y’ed and goes off to each esc.
Battery:
I used a turnigy 2200 3s mainly because I have like 6 of them, and it’s also a common, cheap lipo size.
Receiver:
Any 6 channel receiver that works for you.
Servos:
x4 9g servos (2 for alerons, 1 for elevator, and 1 for the steerable tail wheel)
Maiden:
When I figure out how to add a video I will, but it flew great, only needed a few clicks of trim and it flew great. I think I can get 3-4 minute flights flying at full throttle most of the time.
(Edit) I figured out how to add the maiden video, here it is
Specs:
Top wingspan is 54”
The chord is 7”
Esc:
Battery:
Receiver:
Servos:
Maiden:
