I've been using 4mm bullet connectors on my batteries and ESC's for a while now. Between the 3.5 bullet connectors on the motor side and the 4mm on the battery I've probably soldered at least 50 of these connectors. They are so easy because there is a small hole in the side that allows you to stick the tip of the iron in and heat the solder. It makes it very easy to heat the solder and push the wire into the hole at the same time, making a perfect solder job every time.
I decided to switch everything over to XT60's last night and after about an hour of messing with them I had only solder two XT60 connectors. I could have done a bunch of bullets connections in that time. First, the bullets on the XT60 are cut length wise in half so they don't hold solder like a normal bullet connector does. Also, there is no hole in the side to push the iron through to heat the connector so you have to heat both the wire and the connector at the same time and then push the wire into the connector. I am tinning both the connector and the wire before joining them like your supposed to do. I've watched 4 videos on youtube on soldering the XT60's and I guess I just don't have a strong enough soldering iron to transfer enough heat through the wire and connector at the same time. I'm using a cheap 25 watt iron that doesn't have any adjustments or settings. Maybe its time to invest in a soldering station.
Any of you guys having success soldering XT60's with a cheap 25 watt iron?
