Hello, after the test, I must say that it has improved, the takeoff and entry into the RTH circle has been done correctly and after about three minutes of constant circle to test the repeated error sequence that I comment on the jumps see video, 43sg.
https://drive.google.com/file/d/1U5__zJ9GcuMVPhX1xju-qwv6wXVqkCQ_/view?usp=sharing
I must say that I can not find an explanation for the change in GPS position, these gps do not have a compass like those of the usual drones, then the position should not influence, but I recognize that it has been corrected.
On the other hand, ZOHD does not indicate anything about it anywhere, nor does Beitian.
see photos kopilot gps, three gps have the same position of the antenna with respect to the connector, but a fourth has it the other way around,
However, what has been said is incredible,
thank you Hondo76251
