SP0NZ STD Firewall
Part SP0NZ STD Firewall 1.0
Please log in to download
Type
SP0NZ STD Firewall
This firewall is designed to work with the Flite Test swappable series power pods. Mounting holes are spaced specifically for the Flite Test Power Pack B and Power Pack C motors. Motor attachment is designed for self tapping screws included with these motors. I made the front plate thicker for better thread engagement and to be more resistant to heat distortion. The 3-sided flange was added to have more surface area to glue it in place. There is no need for additional tape to hold this firewall in place.
If you print this and use it, please give feedback so I can continue to improve the design. If you need other hole patterns, hole sizes, or thrust angles, I can easily add those variations. I'm looking forward to your feedback.
* If you like this resource, please rate it. Thanks - SP0NZ
Settings:
My Printer: Anet A8
Material(s): PLA
Rafts: No
Supports: No
Infill: 35%
Layers:
Height:
.2 mm
Top layers: 4
Bottom layers: 4
Perimeters: 3
Author
SP0NZ
Downloads
115
Views
278
First release
Last update
Rating
5.00 star(s) 1 ratings
More resources from SP0NZ
Latest reviews
Fits the standard power pods perfectly.
