Tackling the door has been on my radar for over a year now. When I got the plane there was only a single magnet and friction holding the door and window closed. While that worked fine on the ground, the door would always pop open during flight. The first flight could have been it's last, as when the door flops down (open) it hits the power switch which kills power to the receiver. If it hit hard enough, down she comes!
So I upgraded a few things. First, I modified the power switch so that you push it IN to turn it on, and pull it OUT to turn it off. Now if the door hit the switch nothing bad would happen. In theory? I also added an extra magnet to the door in hopes it would stay closed in flight. No dice, most flights it would still open, but at least I wasn't worried about the power being cut. To keep the door and window closed I resorted to putting a piece of Blenderm tape across both pieces and securing it to the windshield. It wasn't pretty, but did the trick and came off nicely at the end of a day at the field.
Time to FINALLY make a better door latch! I've seen this done a few times on bigger scale Cubs and decided to try it myself. Basically it's a dual latch system with a spring to keep the latch closed at both the front and rear of the door. It's probably easier to just post the pictures than describe how it's made, so here they are.
A spring will be added inside to help keep the latch in the closed position (see pic above). The inner piece is made from heavy brass sheet held in place on a handle made from threaded pushrod material.
The side window will be kept closed by using a couple short metal rods that will key into the top of the door, so the window only opens when the door is opened. In theory...
