Today I built and maiden-ed my first Nutball, but using a Power Pack A, instead of the recommended Power Pack B.
To get the power pack A to work, I used the standard FT Mighty Mini Tiny Trainer power pod, with an extra layer of foam around the bottom and sides so it fit snugly inside the nose portion of the Nutball. In the pics it doesn't look snug because the top/wings helps hold the body together better. I also cut a small "V" section out of the bottom of rear of the body to get the CG right, as it was just barely tail heavy when I put the battery in just behind the power pod (I didn't want it hanging from the bottom). I also had no landing gear, to cut back on weight, and also because I'm only used to hand-launching. Fully assembled, with battery, it weighs only 228g, which is lighter than my Tiny Trainer @ ~290g.
It flew very very well, and shocked me how easy it was to fly in this configuration. I was certain it was going to be severely under powered, but I don't think I ever went above 75% throttle, and I had to cut back quite a bit often to keep it slow. I did have an Aura 5 Lite in it, but had all assistance switched off (no gyros).
I'm extremely pleased with this build and the fact that it flies at all, because I scratch built it, with modifications, and the only other plane I've made or flew was the Tiny Trainer from a speed build kit. I think I might actually like this Nutball better than the Tiny Trainer!
Specs:
Flite Test Power Pack A "Radial Edition"
1806 2280kV motor
5g servos
6x4 prop
3cell, 45c 850mah Tattu battery
Specs:
1806 2280kV motor
5g servos
6x4 prop
