DZFlyer
Hello FliteTest Community,
I recently built an FT Mighty Mini Tiny Tutor (you can see build log here), and I was wondering if anyone knows how long the standard issue battery (2s 800mah 45c Tattu) should last on a flight. I am running the standard setup with Power Pack A and my Tiny Tutor weighs as specified on the FT site (248 grams). I am also running a 6x4.5 direct-drive CCW propeller on the motor (as recommended). I was also wondering whether I can check the voltage of my battery (using a voltage checker and the balance lead) while it is plugged in to the aiplane. If anyone can offer guidance, that would be much appreciated!
