[Help] Power Pack A power cut at full throttle...
Sterner_Polders
Hello,
I purchased a FT Mini Tutor with a Power Pack A and after assembly everything works wonderfully with the exception that at 90%-100% throttle the motor just stops moving. It will spin back up after I drop the throttle back down below 90%. This is my first RC plane and I jump in the deep end with ELRS/EdgeTX. So I don't know if this is a fail-safe in the plane (heat?) or something in the EdgeTX. Any direction is greatly appreciated.
Full Equipment List:
  • FT Mighty Mini Tiny Tutor
  • FT Power Pack A Radial v.2
  • RadioMaster ER6 2.4GHz ELRS PWM Receiver
  • Tattu 800mAh 7.4V 45C 2S1P Lipo Battery Pack With XT30 Plug
  • RadioMaster Pocket Radio Controller (M2) ELRS
Thank you for taking the time to read this.
sterner_polders
Yeah I had a problem once with my brand new ESC, my motor would only go to half speed on full throttle. ESC calibration fixed the problem.
