I wanted to share my latest build, a 10ft Kraken. This is the third Kraken I've put together. The first was the typical build, the second was 100 inches, this is the third.
Spec's
122 inch wing span.
Weight - ?
Motors eflite BL-10's with 12x6. (equivalent to 10 glow).
45 amp ESC's.
5000mah 3s battery. - about 10 minutes of flight time.
8 channel receiver with telemetry, altitude, and gps. (the voltage sensor isn't working yet).
4 9-gram servos, metal gear.
about 13 sheets of DTFB.
LED's the entire wing length. - Ran off a separate battery 800mah, 3s.
a couple paint stirrers and bbq sticks.
Build notes - extended the box spare the entire length of the wing, extended the Kraken wing to a full sheet on each tip. Blunt nose section is one sheet wide. Motors located at the seams to reinforce them. I taped the motors on so they can not be removed for strength (you can slice the tape to open them).
I've never posted a build before so hopefully you have the essence of the build and the pics work.
Spec's
122 inch wing span.
Weight - ?
45 amp ESC's.
