Although I won't start any actual construction for a while I'll get the build thread started since I've got a little time while taking a break from completely cleaning and reorganizing my shop.
The "Stick" is a very popular RC plane design, and has been re-created by countless designers. The shape is fairly simple and the plane is usually easy-ish to build. You can find examples in all sizes, whatever floats your boat. Speaking of that, plenty have been equipped with floats for water action as well.
I've currently got only one flying Stick in my hangar, the Mountain Models Lucky ACE. Even though it hasn't been flown since July of 2017 it's still my most-flown plane with 139 flights and over 18 hours of flight time. Why haven't I flown it for over 14 months? Well, the giant scale bug has bit me hard and most of my flights in the past couple years have been on much larger planes. Here's my ACE, with it's 40" wingspan and 1 pound flying weight.
Time to get a big Stick.... well, a GIANT Stick in this case!
I found a guy in Nebraska selling an old Hobby Shack Giant Stick on RC Groups and pounced on it. For size comparison this is the 50cc Quadra gasser I'm planning to use along with one of the wing ribs. The engine alone is far heavier than the flying weight of the ACE, and the wing rib is about 19.5" long without the leading or trailing edges.
A picture from the box cover - wingspan is 106" (8.8'), flying weight is about 20 pounds, wing chord is 21", and for engine it recommends "Any Giant engine". Kind of vague on the engine recommendation, but this old Quadra should be able to pull it around fairly easily.
Can I get it done during the Build Along's timeframe? Maybe... I'm banking on the straight forward design to help me chug through it in fairly quick time. Once the clean-up in the shop is done I'll do a quick inventory of parts to make sure I'm not missing anything. The box was packed with balsa so I'm optimistic that it's all there.
