Ddm5
Apologies in advance if this counts as a double post.
Right, so my birthday is today and I've got the money to order the parts but I need general advice and reassurance. I posted this pretty much identical thread on the general multirotor part of the forum and it was a minor mistake to begin with. I've been learning how to fly with Micro quads and a large 450 ish sized toy quad so I know the basics and have decent enough control. Any help would be greatly appreciated.
Frame - Genuine F450 or the Q450 (Probably settle on the genuine and pick up a couple of black arms)
Flight Controller - Naza Lite + GPS (For RTH and failsafe, etc)
Motors - SunnySky X2212 KV980.
Props - 1045 SF Props | Black.
ESC's - 30A Emax Simon Series ESC's.
Battery - 3S 2200mah Turnigy Nano Tech.
Charger - (Need advice, can't exceed £25 ish)
Transmitter - Turnigy 9X or Flysky FS-TH9x (They're the same I know)
Reciever - FlySky RX-9X | Comes in the bundle with the FlySky FS.
Extras - Onboard low voltage alarm.
At the moment I'm rather stuck on a couple of key things, primarily the props and battery.
Props: I've seen many different combinations with examples being: 8inch on 4S, 3S 9inch and 10inch on 3S and was wondering if the Sunny's can handle the 10 Inch on 3S. I've seen mixed thoughts about people running the Sunny's on 10 inch and I'm incredibly unsure about it and need advice regarding the prop choice.
Charger: Honestly have no idea what charger to get that's cheap enough for my needs, I'll mostly be charging within the house when I'm on the computer and don't really need to charge them out on the field. I've looked at the Imax B6 and the Imax R6. Still really unsure about what charger to get though.
Battery: Mixed thoughts on the Nano tech since I've seen a guy with 9 or 10 inch props on the Sunny's and he has the throttle end point at 80% due to the power draw. Would I need to do something similar or would the battery suffice?, was also thinking about getting a larger battery, something along the lines of a 4000 or run two 2200's in parallel.
Future plan: Upgrade to a TBS Discovery frame and add the FPV gear down the line.
