I made a V tail DTFB Plane, just to do it. This is a very simple build which uses less than one sheet of foam. It is a two break under cambered wing. The gear is pretty cheap. It is light and bounces around a lot on choppy air. The plane is very aerobatic and responsive. Fun to play with. I used a three channel receiver so I used elevon mixing instead of V tail mixing because V tail requires the 4th channel for rudder.
Here is a 3 flight video compilation.
http://youtu.be/Xf86dPq84Ek
30" Wing Span
7 3/4" Wing Chord
26" Fuselage
10g 2000kv Hextronic
6 amp HK ESC
6x3 Prop
350-500mah 2S
3 Channel reciever
3.6g HK Servo X 2
Here are the plans just incase someone wants to play. Use the snapshot tool and frame the parts as tight as you can. Print Poster at 100%. The plans will print on 8 (2x4) or 9 (3x3) sheets of paper and fit on one piece of DTFB. If you have any questions, let me know. If you build and fly one, let us know.
30" Wing Span
7 3/4" Wing Chord
26" Fuselage
6 amp HK ESC
6x3 Prop
350-500mah 2S
3 Channel reciever
3.6g HK Servo X 2
