perhapsleiana
Sweep of 10 degrees from the root, moving the center of area of the wing about an inch, which would be like moving the battery about 3 inches.If you are doing a sweep of only ten degrees, the CG is really not the problem. I did that with an offset asymmetrical wing of ten degrees and it was under control, but not any 3D. It's the structural stuff that needs addressing like the pivit pin for the sweep mechanism and stripped servos and the wing.
How about some pictures of your setup?
