Built from a stock speed-build kit bought on-site at Flite Fest West, I decided to put my own spin on the SuperBee.
I had a couple of RS2205-2600 red-bottom motors from another project, so they would do nicely. That "other project" was a speedy combat wing, and it was my experiment to see if those RS2205's would hold up on 6S voltage..... They did.
So I'll cut to the chase, here are the dirty details:
Motors: RS2250-2600Kv - http://alofthobbies.com/rs2205-2600kv-ccw.html
Battery: 1550mAh 6s Nano-Tech - https://hobbyking.com/en_us/turnigy-nano-tech-1550mah-6s-65-130c-lipo-pack-450l-heli.html
ESC's: 35A 2-6s Lumenier BLHeli_S ESC - http://www.getfpv.com/lumenier-35a-blheli-s-esc-opto-2-6s.html
(or similar fast 35A racequad ESC)
Props: 4045 KingKong 2-blade props - https://hobbyking.com/en_us/kingkong-4045-red.html
Also flew on HQ-Prop 4045 2-blades
Rx & Servo power: 500mAh 2s + 5V voltage regulator
(not needed if your ESC's have a BEC)
Put all that together and you can have one of these too:
Everything internally is stock - I didn't use ANY carbon or wood reinforcements. My only additions/mods were cosmetic: a strake on the vertical tail to change its "swoop", and a few wingtip/tailtip trims to give it my own personal shape.
CAUTION: This plane is fast. I mean, stinky fast.
