If I select the PPM on the line right after it says Proto, I can cycle through and change PPM to XJT, DSM2, PPM16, PPMSIM, MULTI, or SBUS. Which one of those do I want?
I’d try it to see if it works now. If not tab down to flysky and see what the options are. Look for flysky2 & try it. You may need to rebind the Rx to get it to change.
Was just wondering if maybe that was / would keep that particular esc from thinking its to high to arm. Other then that it would just squeeze in the resolution a bit.
