Brian B
The rear fuselage for the XPS Sea Hawk built in the same way as the fuselage centre section.
The more complex shape and the small radii make the planking a challenge in 5 mm XPS.
The completed rear fuselage glued onto the centre section.
Still the tail surfaces and the fuselage nose section to do.![]()
Did you apply some sort if skim coat to fill before sanding? What is that grayish foam, never seen that before.
